I just finished a new build:
MB: Asrock X570 Taichi (firmware 2.0)
CPU: Ryzen 9 3900X
RAM: 32 GB Trident Z L16-16-16-36 1.35V (F4-3600C16Q-32GTZKK): http://www.gskill.com/specification/...-Specification
I used Ryzen DRAM calculator to set voltages and timings for 3600 MHz (safe preset).
I noticed, it reboots when under heavy load, like compiling Linux kernel with 24 threads. I run stressapptest like this
and I see these errors:
Does it mean there is some problem with RAM?
CPU: Ryzen 9 3900X
Code:
stressapptest -W -M 30474 -s 900 -m 24 --pause_delay 300
Code:
Log: CrcWarmCopyPage CRC mismatch 5e9f7fffa25eaaaaaa4c230aca2a88172311aaaa8799 != ffffffff01ffffffff011002aaaa9ac801002aaaa9ac80, but no miscompares found. Retrying with fresh data. Report Error: miscompare : DIMM Unknown : 1 : 33s Hardware Error: miscompare on CPU 18(0x80) at 0x7fe33b6ffa10(0x0:DIMM Unknown): read:0x3ff9435e60000000, reread:0x3ff9435e60000000 expected:0xaaaaaaaaaaaaaaaa Report Error: miscompare : DIMM Unknown : 1 : 33s Hardware Error: miscompare on CPU 18(0x80) at 0x7fe33b6ffa18(0x0:DIMM Unknown): read:0x0000000000000000, reread:0x0000000000000000 expected:0xaaaaaaaaaaaaaaaa
