Issues with ram xmp settings, default is 2133.
i select xmp profile, restart pc, boots, then shuts off, then on, then off ( about 3 times ) then defaults back to 2133 speed, when i tab back into the bios it still has the same xmp settings enabled, if i let it boot cpu-z shows 2133 speed.
windows also shows (16GB 7.95 usable)
things i have tried:
CMOS clear.
BIOS reinstall
BIOS revert - from F2 to current F42a - f31+ did the ecfw update, followed all the bios update notes from f2-f42a
Reinstalled windows (16GB available 7.95 usable)
Hardware:
Processor - 2700X
Motherboard - AORUS ULTRA X470
RAM - 16GB
(F4-3200C16-8GVKB
GPU - ASUS GTX TURBO 1080
(Detailed MEMORY specs)
Memory SPD
DIMM # 1
SMBus address 0x52
Memory type DDR4
Module format UDIMM
Module Manufacturer(ID) G.Skill (7F7F7F7FCD000000000000)
SDRAM Manufacturer (ID) SK Hynix (AD00000000000000000000)
Size 8192 MBytes
Max bandwidth DDR4-2132 (1066 MHz)
Part number F4-3200C16-8GVKB
Nominal Voltage 1.20 Volts
EPP no
XMP yes
XMP revision 2.0
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 10.0-10-10-24-34 @ 727 MHz
JEDEC #2 11.0-11-11-27-38 @ 800 MHz
JEDEC #3 12.0-12-12-29-41 @ 872 MHz
JEDEC #4 13.0-14-14-32-45 @ 945 MHz
JEDEC #5 14.0-14-14-34-48 @ 1018 MHz
JEDEC #6 15.0-15-15-36-50 @ 1066 MHz
JEDEC #7 16.0-15-15-36-50 @ 1066 MHz
XMP profile XMP-3200
Specification DDR4-3200
Voltage level 1.350 Volts
Min Cycle time 0.625 ns (1600 MHz)
Max CL 16.0
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tRAS 23.75 ns
Min tRC 35.00 ns
Min tRRD 3.50 ns
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 16.0-18-18-38-56-n.a @ 1600 MHz (1.350 Volts)
DIMM # 2
SMBus address 0x53
Memory type DDR4
Module format UDIMM
Size 8192 MBytes
EPP no
XMP yes
XMP revision 2.0
AMP no
Max CL 16.0
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tRAS 23.75 ns
Min tRC 35.00 ns
Min tRRD 3.50 ns
Any help would be lovely, thank you in advance, ive been trying to fix this issue for over 2 weeks, i dont want to have to RMA my parts.
CMOS clear.
BIOS reinstall
Hardware:
Processor - 2700X
RAM - 16GB
(F4-3200C16-8GVKB
Memory SPD
DIMM # 1
SMBus address 0x52
Memory type DDR4
Module format UDIMM
Size 8192 MBytes
EPP no
XMP yes
XMP revision 2.0
AMP no
Max CL 16.0
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tRAS 23.75 ns
Min tRC 35.00 ns
Min tRRD 3.50 ns
DIMM # 2
SMBus address 0x53
Memory type DDR4
Module format UDIMM
Size 8192 MBytes
EPP no
XMP yes
XMP revision 2.0
AMP no
Max CL 16.0
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tRAS 23.75 ns
Min tRC 35.00 ns
Min tRRD 3.50 ns
