new build amd 3900x and trident rgb
  • new build amd 3900x and trident rgb
    I just bought this memory and would like to know it it will fly with a amd x570 aorus ultra board F4-3200C16Q-32GTZR 8GB x4 kit
    Skylake-X i7-8720X @ 4.7GHz Delid
    Gigabyte Aorus Gaming 7
    32GB PC3200 DDR4 @3400 GSkill Trident Z
    Corsair H115i
    Coolermaster v1000 Gold Series PS
    MSI GTX1070 Gaming X 8G
    OCZ RD400 NVME M2 512GB SSD for OS
    corsair K95 RGB Keyboard
    corsair CS Air540 Cube case
    Asus Essence STX II 7.1 | Energy Take Classic 7.1
    Onkyo TX-NR809
    Windows 10 ENT x64
    Asus Rt-AC88U
    It can work, use the latest BIOS for best results.
      Ok,thank you !!
      Corsair H115i
      Onkyo TX-NR809
      Windows 10 ENT x64
      Asus Rt-AC88U
        what's the difference between the gtzr and the gtzrx ?
        Corsair H115i
        Onkyo TX-NR809
        Windows 10 ENT x64
        Asus Rt-AC88U
          RX version designed and tested for AMD CPUs however the latest BIOS versions can essentially support both types.
            the gtzr worked fine ,no issues
            Corsair H115i
            Onkyo TX-NR809
            Windows 10 ENT x64
            Asus Rt-AC88U
