I had to update the bios on my motherboard so that the mobo could recognise my new 2600x cpu. All went 100% correct.
I've been having problems on and off with bluescreens and finally found the issue. When i go in to the bios I find, that even with XMP over clocking disabled, the ram is running at 2400mhz. If i click XMP1, the ram then drops down to 2133mhz. If i select XMP2 no change happens. To get the system to run stable I've had to turn off automatic detection and set the ram to run at DDR4 1866. I'm not sure if this is a RAM problem or a bios problem.
Any help would be appreciated.
