Will G.Skill Flare X 32GB (4 x 8GB 14-14-14-34) work with Ryzen 7 2700X?
  • Will G.Skill Flare X 32GB (4 x 8GB 14-14-14-34) work with Ryzen 7 2700X?
    I've seen this kit, but it's not clear whether it's for Threadripper or it can work with Ryzen 7 as well (at 3200 MHz).
    I have Asrock X370 / Ryzen 2700X combination.
    It can work for Ryzen 7 as well, max DRAM Frequency depends on CPU OC margin
      Got it, thanks! I'll give it a try then.
        These kits are out of stock on Newegg for a while already. Are you still making them / will they get restocked?
          Please yourself on the auto notify list, contact NewEgg to let them know you are interested and they will get that to you as soon as possible.
            I just bought one kit from another seller (still through Newegg). Waiting for the order to get processed.
              That didn't go well, the seller said the order will be delayed for weeks, so I cancelled it. I'll wait until it will appear from Newegg proper.
                I'm looking at: https://www.newegg.com/Product/Produ...-623-_-Product
                There is no backorder option there and no autonotify either for some reason.
                  Contact them directly to let them know you are interested and they will set it up for you.
