X470 & F4-3200C14D-32GTZ
  • X470 & F4-3200C14D-32GTZ
    I'm going to buy a ryzen system with a gigabyte x470 aorus gaming7, i would like to use this gskill kit F4-3200C14D-32GTZ, 2x16gb, it's easy for me to buy here in italy, but i've seen that this kit it's not listed in gigabyte qvl, i need some advice, i could get some problems? I've seen a lot of people using in x370 systems, and someone in an asus ch x470, with manual settings.
    Thanks a lot
    Bye
    This is not a kit you will find on G.SKILLs QVL or someone official would recommend for your mainboard. However it is a popular kit for AM4 builds among enthusiasts regardless. It usually needs manual settings to reach DDR4-3200 on AM4. So the actual Vdimm needed might be a bit higher and it requires manual adjustment of sub-timings and/or some AMD specific settings.
    So would you rather have a plug and play experience or are you comfortable with manual testing and tweaking?
      Thanks a lot for the answer,
      i'm used to manual configurations, so it will not be a problem, but i need to be sure that the kit will work in some way, at least at 3200, thanks again for your clarification
        It will work at default settings, so DDR4-2133 CL15 1.2V.
        To reach DDR4-3200 you will very likely need manual settings, since XMP-Auto is not guaranteed to work. If you invest enough time and are either willing to raise Vdimm above 1.35V or relax timings a bit, then DDR4-3200 should be pretty safe to reach on any decent AM4 board. I don't have personal experience with your X470 Gaming7 and so can't comment on how good of a memclocker it is (but probably not too far behind the Crosshairs).
