Let me preface this by saying that I'm a novice at overclocking so I need detailed instructions and explanations! I thought it would be better to ask here and not just randomly try things.
Problem:
When I enable the XMP profile on my RAM the CPU stays at max clocks even when idle, I've tried it with stock CPU clocks and overclocked.
Also with XMP on when I try to shut down the PC it doesn't turn off. My monitors go black, HDD's sound like they turn off but all the fans and lights stay on. I've left it in that state for like 5 minutes but nothing happens.
Both of those problems also happen when I tried increasing the ram clock slightly from the default 2133 MHz while leaving timings and other settings to automatic.
My BIOS version is 1.30.
Problem:
