Q-Code 55 with Ripjaws V 1800MHz CL16 + Maximus VIII Hero + i5 6600K 4.5GHz
  • Q-Code 55 with Ripjaws V 1800MHz CL16 + Maximus VIII Hero + i5 6600K 4.5GHz
    Hi, I have an assembled computer desktop with this specs: http://valid.x86.fr/mgxir5
    Sometimes, when I turn it on, the Asus Maximus VIII Hero motherboard show Q-Code "55" (more often at reboot; the manual says "Memory not installed"), and I need to forze to shutdown and then turn it on again hoping it doesn't show it again. Few times it show Q-Code "34" (the manual says "CPU post-meemory initialization") instead of "55".
    I tried to install only one memory kit (3600C16D-16GVK) of 8GB instead of 2 x 16GB, but didn't work either. When using the memory and XMP 2.0 configuration but with the CPU at lower speed (3.5 without boost) the problem didn't occured. Is there some way so solve? Thank you.
    Boost CPU vCore slightly to see if you can stabilize the processor
      I have vCore at offset mode (1.37V max). Can I push it even more manually?
        Yes, you can increase and lower frequency based on how the system responds to the change.
