F4-3200C14D-32GTZ speed?
  • F4-3200C14D-32GTZ speed?
    hi
    am using G.skill F4-3200C14D-32GTZ DDR4 Ram on gigabyte x370 gaming k7 motherboard, Ryzen 1800x , 650 PSU, Radeon RX460 WINDFORCE OC 4G.
    just need to know why I can't use it with speed of 4000 ?
    when I enable the XMP the auto setting gives the speed of 3200 , manually maximum i could reach 3300 maximum, anything faster than that it will not work ans work on 2100.
    is this Bios compatibility issue or there is something else I should do?
    and can you someone please send me a good tutorial for manual DDR4 Overclocking, I tried to search myself but most of what I found was not that helpful.
    It is near limits for the motherboard and CPU. Some CPUs can't even reach 3200. Luck required
