Memory For Ryzen
  • Memory For Ryzen
    Hello there everyone,
    I am planning a build on the ryzen platform:
    Crosshair VI Hero
    Ryzen 7 1800X
    and i've been checking Ram ever since I've picked both board and CPU.
    I know for a fact that the ryzen runs better and it's more stable when paired with a Samsung B single rank memory.
    I do know that GSkill has launched their Fortis and Flare X kits but I'd like to know if there are any more kits that will match that criteria (Samsung B single rank).
    So apart from the Flare X kit (F4-3200C14D-16GFX) (3200 - 3467mhz)
    is there any other kit?
    I was thinking of maybe buying the F4-3600C16D-16GTZR and downclock it to match F4-3200C14D-16GTZR speeds and timmings.
    Is this RAM Samsung B and Single ranked?
    I don't know if Ryzen will ever allow us to use memory at 3600mhz out of the box but that way i'd already have the RAM for it
    What do you guys think?
    That should work, others have done the same.
    Yes it is.
      Thanks a lot emissary42
