F4-3200C14D-32GTZ on Asrock z170 OC Formula?
  • F4-3200C14D-32GTZ on Asrock z170 OC Formula?
    Is the G.SKILL TridentZ Series 32GB (2 x 16GB) DDR4 3200 CL14 memory compatible with the motherboard ASROCK z170 OC Formula?
    It's not in the RAM compatibility list, but I know they can't test everything.
    Also, will XMP work with this configuration?
    Thanks for the help.
    Should work with the latest BIOS
      Just to follow up and confirm. It did work and the XMP also worked splendidly. You guys are the best.
        Thanks for the update, really appreciate. Glad to hear you got everything working properly. Should perform like one of the fastest computers a person can build.
