F4-2666C15Q-32GRR help
  • F4-2666C15Q-32GRR help
    Hi -- I'd like to buy the DDR4 sticks w/ product number F4-2666C15Q-32GRR. They come in packs of 4x8GB. My question is whether I can trust that 2 packages (for a total of 64gb ram) will work together -- or should I instead wait for a 64gb matched pack.
    Thanks.
    Scott
    It's best to get a matched 64GB kit. The rated specifications are no longer guaranteed with two separate kits.
      Thanks for the reply. Any idea on when there's going to be 64gb kits? I only see 32gb at present.
      sd
        All in time, maybe a few weeks.
