Ok, so this is my motherboard: GIGABYTE GA-Z77X-UD5H
This is my CPU: Intel Core i7-3770K Ivy Bridge 3.5GHz
And the RAM: ARES 16GB (2x8GB) DDR3 1600
All hardware is set to stock bus speeds and multipliers.
Like many of the NewEgg commentors, this board defaults the RAM to 1333MHz. It calls them 1600MHz, but it says the actual speed is 1333MHz based on the multiplier of 13.33. Now I figured out how to change the multiplier to 16.00 and that seems to put it at the correct value of 1600MHz (10-10-10-30), but I wanted to be sure that was the right thing/way to change for this memory. I see all sorts of voltage numbers, etc that I'm extremely leary of touching for fear of damaging the brand new system.
Being a new system and new to the SATA era PC builds I'm also trying to make sure I get everything tested before my RMA periods expire. I tried using the Windows 7 x64 installation DVD to run the WMD, but I kept getting an error. I tried it once from within Windows (triggering a reboot) and it sent me into the Diagnostic tool post-boot. I chose the most detailed option and left the cycles to default. Any idea how long that would have taken to complete? Is it Really testing all 16GB of RAM? Any clue as to why the Boot DVD utility wasn't working, but the in-OS one was? If it matters, the DVD is pre-PS1 and the installation was post-SP1. Perhaps I should create a Slipstream disc?
Now hopefully I'll remember to make my way back here. >.<
