Hi everybody. I was wondering if somebody can give me some advice on the issue I am having. My computer has run perfectly fine since assembling it 6 months ago. Then this Saturday computer out of nowhere started freezing and geting blue screens. Did a memory test with memtest86 and got millions of errors. So, thinking sticks are issue. took each one out and retested all good. tested 2 together all good. tested three together all good. Put four in computer would just turn on and off and on and off. Had to remove sticks and put in one by one to get computer to come up. Doesn't seem like a memory stick issue but setting issue maybe. My motherboard is a gigabyte z68mx-ud2h-b3. All sticks were part of a kit. Intel i7 2600k. I'm not really familar with memory settings in BIOS and what they do but have tried to change DRAM voltage still the same many errors, turned on XMP still the same. Loaded newest firmware still the same. One thing I did notice is in the BIOS the timings were set at 11-11-11-32 but sticks are 9-9-9-24-2N. Changed that still the same. Downloaded CPU-Z and it says FSBRAM is 1:6, i read it should be 1:1.
If anybody has any suggestions on what to change in BIOS any help would be appreciated at this time. totally lost. If I lower speed of sticks do timings get changed and to want. Would not mind running memory at 1333 instead of 1600.
Thanks,
Mario P.
Thanks,
Mario P.
