I have a new build with a AsusM4A89GTD pro usb3.0 mb. I have gskill 12800cl9d 1600 4gigx2 and 2gigx2 and I've read that the different capacities aren't compatible, even though all specs are the same except capacity. I have tested the memory w/ memtest 86 v/ 4.0 and I get massive errors at the block test. I have taken each one,individually, of the module and tested and one of the 4gig mods runs errors on the block test. The other 4gig module runs clean. Do I need to return this module that is getting the errors?
Compatibility
If running them separately under Memtest and getting errors, prob want to RMA it, can contact your local vendor or etailer, or go through GSkill, contact them at (world) rma@gskill.com or in the Americas contact rma@gskillusa.com
