RipJaws': F3-10666CL7D-4GBRH
The Asus M4N98TD EVO is a Nvidia 980a SLI AMD Socket Board. 1 of only 2 I've ever found.
Website http://www.gskill.com/products.php?index=223 Shows:
CAS Latency 7-7-7-21-2N <------------------
I need to know what the Bank Cycle time (tRC) and
the Command Rate (CR)
is suppose to be set at.
And what does the 2N stand for?
I have 2x Sets of 4Gb
for a total of 8gb's All work stable @ manual Config of:
Type DDR3
Size 8192 MBytes
Channels # Dual
DRAM frequency 666.7 MHz <---Accurate?
CAS# Latency (CL) 7 clocks
RAS# to CAS# delay (tRCD) 7 clocks
RAS# precharge (tRP) 7 clocks
Cycle time (tRAS) 21 clocks
Bank cycle time (tRС) 33 clocks <---------Accurate?
Command rate (CR) 2T <--------- Accurate?
Thanks for all the Info
Type DDR3
Size 8192 MBytes
Channels # Dual
