I am not sure but I thought I had to get compatible memory from the list on ASUS for my upcoming CrossHair 4. But I was told that the majority of g.skill's memory should be fine, and to just make sure its 2000 16000 for best performance.
Well the Tridents are on the list, but I was wondering if the PIS F3-16000CL7D-4GBPIS
would be compatible on the crosshair 4??
I have decided on getting the V8, from what I can tell it is so high up that the PIS and
its S-Fan that comes with it shouldn't be a problem esp. in the HAF-X I want to put them in!
