Hi all, I just finished my first PC build the other day, but i'm having trouble with the XMP on my Trident F3-12800CL8D-4GBTD Memory. I'm running it with an Intel Core i5 750 on a Gigabyte p55a-ud3.
The board and the memory both support X.M.P but when i enable it in the BIOS it causes my CPU to massively overheat, with x.m.p. on, it idles around 50 c and within 2 minutes of being put under full load it will hit high 80's and soon into 90's. I thought i maybe didnt install the cooler properly (its not aftermarket and i stuck with the thermal grease that is initially on the base of the heatsink) but when i checked it was definitely on as it should be. I then tried turning my X.M.P off and my temperatures went to were they should be, 38ish at idle and 68ish at full load. Im just wondering why this is, i have done no manual oc'ing (just swithching my x.m.p on and off) and with x.m.p on the memory was running at its advertised speeds and timings, at 1.6 volts (as opposed to 1.5 without x.m.p). Anyone else noticed anythig similar? Have a solution? I would appreciate anyones help with this! Also note i live in ireland and it is late here so i may not be back on the forum for several hours!
