Hi there...
I have some questions for the tech support guys...
I have changed the settings on my bios and set the timings manually to 7-7-7-21-1T running on 1333mhz and voltage to 1.5V.My pc is running smoothly until now without failing on memtest or crashing.Of course i was very pleased but what i don't understand is if the DRAM frequency the cpu-z shows is accurate considering that i changed via bios and if the tRC is correct...
My big question is ''Do you approve my settings for this product and if not what is your suggestion for tighter timings?''
Here are my specs:
MOBO:ASUS M4A79T DELUXE
RAM:F3-10666CL9D-4GBRL 4GB (2X2GB) DDR3 PC3-10666 1333MHZ RIPJAWS DUAL CHANNEL KIT
CPU:AMD PHENOM II X4 955 3.2GHZ QUAD CORE BLACK BOX EDITION
OS:MICROSOFT WINDOWS 7 HOME PREMIUM 64-BIT
Thank you very much in advance and sorry for my miserable english....
Here are my specs:
