F3-10666cl8d-4gbhk
  • F3-10666cl8d-4gbhk
    F3-10666CL8D-4GBHK ram
    asus p7p55d delux
    i7 860 prossesor
    my computer boots and is fine but only says there is 2g installed it is not regersting one of the sticks
    When installing memory, please make sure to firmly press down on BOTH sides to insure a proper installation. Also, make sure XMP Profile is enabled or memory settings are manually configured to operate the memory package properly. Let me know how that goes.
      i know the memory is seated properly but not sure how to do the xmp profile or the memory settings are correct
        In BIOS, for AI Overclock Tuner, set that to XMP.
          well i changed it to xmp but nothing changed i have cpuz and it is saying i only have it sett up for single channel ram
            Can you post screen shots of your BIOS settings
              What slots do you have them installed in?
                what is the easyest way to take screenshots in the bios and i have them installed in slot A1 B1 Like the motherboard says to
