I see that you updated your compatibility with the [ Perfect Storm ] F3-16000CL8T-6GBPS to include the Gene II at 2000MHZ memory speed. I do see your guide for the F3-16000CL9T-6GBTD + ASUS Rampage II Extreme BIOS Settings. However I tried these in the past and was unable to get the ram to run at 2000MHZ. I order new memory from Newegg and replaced the MB (Also tried single sticks at a time).
I was told it could be a MB issue or RAM issue, no change at all still crashes on Vista Load (Sometimes loads and then crashes during testing) at 2000mhz memory speed. I have been running my system stable at 1600MHZ memory speed and 4.0GHZ OC on the processor for the last 2 months under load, temps at 45C. I saw that Asus released another bios update. I wanted to find out if you guys have been able to get the GENE II MB to run the memory at 2000MHZ yet and what settings you used? I tried many different configurations. Hoping for some new tricks, tips or a new configuration. Just a note my memory and mb are not bad.
