So here is what I'm trying to do.
I have 32GB (4x8GB) Trident X RAM. F3-1866C8D-16GTX to be exact.
However BIOS can see only 16GB @1866MHz or 24GB @1333MHz.
When I boot into Windows 10 PRO system information says 32GB installed but only 16 (or 24) is usable.
CPU-Z also reports exact BIOS information including single channel mode instead of dual.
2X8GB modules separately work perfectly fine.
Is there any way to make my motherboard see 32GB @1866MHz? Tried swapping modules and reseting bios etc..
CPU AMD FX 8350 and the latest Asus bios. v2901
Thank you.
Thank you.
