module compatibility
  • module compatibility
    I am presently running G.SKILL SNIPER 8GB 2x4GB DDR3-1866 F3-14900CL9D-8GBSR CL9 DIMM 240pin on an ASUS M5A99FX PRO R2.0
    Are the following modules compatible to run on the same system in conjunction with the former? The voltage, latency and timings seem identical. If not, which one can I add to up my memory to 16gb? The Snipers are very hard to find and even used, tend to be very pricey.
    G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL9D-8GBXL
    There is no guarantee when mixing separate memory kits. Only a single kit of RAM should be used in each system. You can try the same spec RAM like the 8GBXL kit to see how well they can work together
