not working : Gskill AEGIS DDR3-1600MHz 2x4GB
  • not working : Gskill AEGIS DDR3-1600MHz 2x4GB
    my old rams work just fine , i bought some gskills and when i put them on the computer keeps rebooting until it frezes
    i updated my bios tried overcloking , changed to cl 11 11 11 28 , changed the voltage..
    idk what to do more, i would apreciate some help .
    ty for the attention
    my specs:
    motherboard : P7H55-M PRO MT700CK02400646
    Ram (the ones i have working now)- Corsair 4GB XMS3 2x 2GB DDR3 1600Mhz
    Ram (the new ones) - Gskill AEGIS DDR3-1600MHz 2x4GB
    graphic card - asus gtx 1050 ti
    processor - Intel Core i5 661
    You need one of these:
    F3-10666CL9D-8GBNT
    F3-1600C11D-8GNT
      so the ones i bought wont work ?
      can you explain me why ? to learn
        It is an older system so it can only support a specific memory type, low density. Newer modules are high density and may not work since the BIOS never received any updates for the newer DDR3 modules.
