Reporting Wrong Speed
  • Reporting Wrong Speed
    Please tell us the detail of your system spec
    model of the motherboard: ASUS Striker II NSE (bios 0601)
    model of the memory:F3-12800CL7-2GBHZ (8gig)
    model of the CPU:Intel Core 2 Quad 9450 @ 3.5MHZ
    model of Graphics Card: BFG 260GTX
    model of Power Supply: Thermaltake 850W Toughpower
    Model of Audio Card: Supreme FXII
    Model of Physics Card: BFG 128 meg
    Model of Hard Drive: WD Velociraptor x2 Raid 0 ( Vista Ultimate 64)
    Model of Hard Drive: WD Velociraptor x1 (XP Pro)
    Model of Optic Drives: Asus DRW-2014L1T DVD +-R/RW Drive (X2)
    Model of Case: Cooler Master CM690
    Model of Card Reader: Roseville 9in1
    Model of Memory Cooler: Corsair Dominator
    CPU, Graphics, Northbridge Watercooled using various parts from Danger Den
    7 - 120mm case fans @ 1200rpm
    24" Samsung SyncMaster 2493HM
    RocketFish Blue Tooth Keyboard and Mouse Combo
    what is the problem:
    Ive tried several programs Everest Ultimate and others that report my memory as DDR3-1333 (667 MHZ)
    Memory settings are: 7-7-7-18 1.9v
    Can you please tell me what settings I need to change and the values to benchmark the memory to the Advertised speeds of 1600MHZ (800mhz)
    we'd recommend you to install only two modules
    4 sticks of DDR3 1600 are not recommended on this board
    thanks
    G.S
      Poor Answer
      I was hoping to get a better response than that!
      can you please elaberate on your answer? Why cant I run all 8 gig in Vista Ultimate 64????
      you should be able to run 128 gig in Vista 64, whats the reason your asking me to only run 2 sticks? I dont understand? running 4 sticks is what I built this computer for. PLease advise the correct settings to be able to run all 4 sticks in my system. So far Im thinking Gskill is trying to scam the public with there Tactics of selling memory that is suppose to run at a certain speed and then the consumer not able to reach the specified speeds.
        it's about chipset, the the system
        there is problem with 4 sticks on Nvidia chipset while running DDR3 1600
        G.S
          Please try CL8-TRP7-TRCD7-TRAS18. This setting is good for nvidia 790i motherboard. if you have any update please let us know
