Can I run F3-2400C10Q-32GTX at 1600MHz and 1.5v?
  • Can I run F3-2400C10Q-32GTX at 1600MHz and 1.5v?
    could you please help me with two questions?
    (1) Is this F3-2400C10Q-32GTX memory kit compatible with an Intel DQ77CP motherboard and an i7-3770?
    (2) If so, can I run this kit at 1600MHz and 1.5v?
    If you are not using the XMP, it defaults to DDR3-1333 at 1.50V. So for DDR3-1600 you would have to manually configure the memory settings. A kit like this shouldn't have any trouble running DDR3-1600 9-9-9-24 at 1.50V. Then run some stability tests just to make sure, since these settings were not factory tested.
      Thank you.
      And I assume my motherboard is indeed compatible?
        In theory at least, but this configuration was probably never tested by either G.SKILL or Intel.
