Tried 2 identical dual channel sets and a quad channel set BSODS
  • Tried 2 identical dual channel sets and a quad channel set BSODS
    Hey so first off here is my setup:
    asus z87-a
    i5 4670k
    noctua nh-d15
    currently just 1 set of 2x4 gskill ripjaw x 1600 cl9
    I have recently been trying to make use of a second identical set of dual channel 2x4 gskill ripjaw x 1600 cl9 and even tried with a quad channel ripjaw z 2133 cl9 and had the same issue. I also experienced the same issues when attempting the same thing in my Msi z97 gaming 5 + 4690k and i would get random bsods. At first I suspected that i just couldn't get the two identical sets to work with one another but after trying the quad set i figure there must be something else at fault here. I have heard of lots of people having difficulties filling all 4 dimm slots on some motherboards and needing to adjust certain voltages to achieve stability but i haven't come across any solved cases where someone has come back with results on how they achieved stability. Any help with this issue would be much appreciated as i have a poor lonely set of 2x4 1600 gskill ripjaw x cl9 that wants to be put to good use!!
    Do you have the latest BIOS?
    What settings are you attempting?
    1333 and 1600 have problems?
    Is each dual channel kit able to run at full speed?
