Finding RAM for my pc?
  • Finding RAM for my pc?
    Before I buy some G.Skill RAM I would like to be sure it will work, and, want to find out the performance gain if any from something like I am using now. Here is my pc, and a some of my Speccy Info.
    http://www.dell.com/support/home/us/...n-660s/manuals
    I looked it up myself but I am not all that confident that I got it right, here is that link also.
    A few things are different, and in the Finder I did not see the options exactly as I have in my pc. Latency is different for one thing.
    https://www.gskill.com/en/product/f3-8500cl7d-8gbrl
    I only have one slot filled with one 4GB Samsung Chip, and this is the first Block of info in my Speccy Chart. I want to go with 8GB Total as in the link above, but want to make sure it will work because I'm on a tight budget. If any more info is needed please just say so.
    Number Of SPD Modules 1
    Slot #1
    Type DDR3
    Size 4096 MBytes
    Manufacturer Samsung
    Max Bandwidth PC3-12800 (800 MHz)
    Part Number M378B5173QH0-CK0
    Serial Number 3512206592
    Week/year 32 / 13
    Timing table
    JEDEC #1
    Frequency 457.1 MHz
    CAS# Latency 6.0
    RAS# To CAS# 6
    RAS# Precharge 6
    tRAS 16
    tRC 22
    Voltage 1.500 V
    Thanks, CB
    F3-10666CL9D-8GBNT
    This model may be best
      Unfortunately I did not get this message to my inbox, so bought the matching Samsung chip? What should I do to rectify this?
      I don't Overclock, at least with this pc. It is a low powered pc from what I understand, the Power saving type, so the PSU is not all that powerful and don't know if overlcocking will be a good thing.
        If you already ordered it, try it and see how it works.
          The important thing is, I'm not getting Notifications to my email Inbox. When I make a little more money, or need new RAM would like to be able to get info from here quickly.
            If you don't receive notifications on new answers, check if
            > Control Panel
            >> Settings & Options
            >>> Edit Options
            >>>> Default Thread Subscription Mode
            is disabled (do not subscribe/no email notification) and instead set it to instant email notification.
