F3-14900CL8D-8GBXM what other 4x2GB will fit
  • F3-14900CL8D-8GBXM what other 4x2GB will fit
    Motherboard: Asrock Z87 Pro 4
    CPU: Pentium i5 3.2 4670
    Memory: F3-14900CL8D-8GBXM
    I want to add more RAM to my computer, but i cant find in my country this same Memory.
    I'll try F3-14900CL9D-8GBSR , but i have blue screen sometimes. They have only CL time different.
    Do you think that G.Skill RIPJAWS 8GB 2x4GB 2133MHz CL9 F3-1700 , can work with my RAM? or can you say what parameters must match if i want to buy different ?
    Better buy strongest and change timing to lower, or its random, some RAM will work together, other not. Do you have some hint or model that should wark?
    Try similar or sold that, and buy new?
    We can only guarantee a single kit of RAM to work and run at full specs. Anything else is not guaranteed since they were not tested together in that order from factory.
    Sell the old RAM and buy new is ideal.
