Help buying memory for a HP Pavilion dm4-1280sl
  • Help buying memory for a HP Pavilion dm4-1280sl
    I'd like to buy 2x4GB of SODIMM DDR3-1333 PC3-10600 @667MHz CL=9 for a HP Pavilion dm4-1280sl model currently equipped with 2x2GB of similar SODIMM and a Core 2 Duo i5 M430@2.27 GHz (SKU: WQ086EA)
    I haven't found the voltage, but I think it's 1.5V. Could you confirm that the kit I need to buy is the kit F3-10600CL9D-8GBSQ ?
    Where should I buy it from ?
    Thanks in advance for your help,
    Bruno.
    Yes, that is the correct model. Best place to purchase is NewEgg if you are in the USA.
      And in Europe ?
      Any recommendation for the Euro zone ?
        Check here
        https://www.gskill.com/en/wheretobuy
