Help choosing RAM
  • Help choosing RAM
    I've recently bought a new RAM from G.SKILL that was incompatible with my motherboard (ASUS P7H55-M LX), what 8x2 GB RAM should be compatible?
    You board only has two memory slots, so you need a dual kit not a double quad kit of eight modules. Here in the forums the usual recommendation for older setups is G.SKILL F3-10666CL9D-8GBNT, but i have not tested that combination myself.
    If you meant 2x8GB instead, i don't know if any of those kits are compatible with LGA1156 in general and your ASUS P7H55-M LX in specific.
      Thanks, about 8x2, I meant 2x8gb, I didn't realized until you said it.
