32GB for Asus Sabertooth 990FX R2.0
  • 32GB for Asus Sabertooth 990FX R2.0
    Approved QVL Ram for this board is
    F3-19200CL10Q-32GBZHD -G.SKILL Ripjaws Z Series 32GB (4 x 8GB)2400 (PC3 19200)
    Is there a difference between this and the one below? all I see is it has 2 sets of fans
    F3-2400C11Q-32GZM
    G.SKILL Ripjaws Z Series 32GB (4 x 8GB) 2400 (PC3 19200)
    Also will either of these work at 2400mhz
    F3-2400C10Q-32GTX-
    G.SKILL TridentX Series 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200)
    Or
    F3-2400C11Q-3
    G.SKILL Sniper Series 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200) Desktop Memory Model
    Timings, the CL10 model is better.
      I guess I missed the timings, thanks for pointing that out, would the CL11 also *** for QVL since only the timing is different and could I use the snipers or tridents?
