Would be grateful for any pointers for a fix.
I have had a set of F3-2400C11Q-32GXM (this is the ID# on the packaging card) 4x8GB for a while (since June 2014 from GSkill on Amazon.co.uk ) in the following mobo (both QVLs match) and it has been throwing BSODs about twice a month since I began to use it full time in April this year. This is a problem because I like to help out by beta testing games and I cant make useful bug reports if my rig is misbehaving.
Mobo: Gigabyte GA-Z97MX-Gaming 5 (1.0) BIOS:F4
VGA: GTX 770 (GV-N770OC-2GD)
OS: Win 7 Ult x64 SP1
CPU I7 4790K #SR219
RAM GSkill 32GB F3-2400C11Q-32GXM
PSU: Seasonic 860W Platinum SS-860XP2
SSD: M550 1TB & BX100 1TB (latest firmware)
Previous testing found no RAM errors and I started a thread (with all the BSOD info) to try to find the problem as below.
http://forums.guru3d.com/showthread.php?t=403048
Recently more extensive retesting with Memtest86+ and Memtest86 v6.2.0 have shown rare errors from the RAM at XMP timings and clocks with mobo vRAM set 1.66v and BIOS monitor reading 1.69v. (When the BSODs started the volts were on auto / XMP and the mobo showed 1.65v set, I switched to manual to try to stabilise the system and the BIOS was +/- 0.02v so it was either 1.64v or 1.66v).
Re cooling and clocking etc: the CPU is not overclocked at all and is running at stock with turbo disabled in order to ensure there is no overheating even in stress testing with OCCT and AIDA64. Neither the CPU nor the RAM has ever been overclocked as the intention was to make a lightweight gaming box hence mATX form factor and air cooling. The CPU heatsink is a Noctua NH-L12 low profile and it has a big Noctua fan which makes a current of air over the RAM. Case is open sided for testing and it is a LianLi PC-V354 with 2x120mm stock fans in at the front and Akasa Viper S-Flow 120mm+140mm out, so well ventilated.
So the question is how do I fix the errors? Given that Memtest86 v6.2.0 tests CPU cache as well as RAM it isnt good logic to assume it is the RAM just yet. But it is reasonable to see if the errors can be stopped by remedies directed at the RAM.
Interestingly Memtest86 v6.2.0 was reading it as PC-18200 not PC-19200 as stated on the packaging. Does that mean it is an overclocked chip or is Memtest86 making an ID error? Is Memtest86 v6.2.0 reliable and/or is this a known thing about this model, if so is there a well trodden path to success?
Either way I just want it to work without errors and would appreciate advice. I am happy to tweak it if that works. So I am asking is it advisable to boost the volts some to try to stabilise it? If so how far can it safely go bearing in mind the mobo monitor is reporting higher volts than set. Or should I play it safe and try to get proof to invoke the lifetime warranty?
CPU I7 4790K #SR219
Code:
Report Date 2015-12-15 12:22:57 Generated by MemTest86 V6.2.0 Free (64-bit) Result FAIL System Information EFI Specifications 2.31 CPU Type Intel Core i7-4790K @ 4.00GHz CPU Clock 4000 MHz # Logical Processors 8 L1 Cache 4 x 64K (209669 MB/s) L2 Cache 4 x 256K (60830 MB/s) L3 Cache 8192K (45375 MB/s) Memory 32815M (24718 MB/s) DIMM Slot #0 8GB DDR3 XMP PC3-18200 / F3-2400C11-8GXM 10-12-12-29 / 1142 MHz / 1.650V DIMM Slot #1 8GB DDR3 XMP PC3-18200 / F3-2400C11-8GXM 10-12-12-29 / 1142 MHz / 1.650V DIMM Slot #2 8GB DDR3 XMP PC3-18200 / F3-2400C11-8GXM 10-12-12-29 / 1142 MHz / 1.650V DIMM Slot #3 8GB DDR3 XMP PC3-18200 / F3-2400C11-8GXM 10-12-12-29 / 1142 MHz / 1.650V Result summary Test Start Time 2015-12-14 23:26:44 Elapsed Time 12:56:00 Memory Range Tested 0x0 - 82FE00000 (33534MB) CPU Selection Mode Single: CPU # 0 # Tests Passed 34/35 (97%) Lowest Error Address 0x49B51AC4C (18869MB) Highest Error Address 0x49B51AC4C (18869MB) Bits in Error Mask 0000000000010000 Bits in Error 1 Max Contiguous Errors 1 Test # Tests Passed Errors Test 0 [Address test, walking ones, 1 CPU] 3/3 (100%) 0 Test 1 [Address test, own address, 1 CPU] 3/3 (100%) 0 Test 2 [Address test, own address] 3/3 (100%) 0 Test 3 [Moving inversions, ones & zeroes] 3/3 (100%) 0 Test 4 [Moving inversions, 8-bit pattern] 3/3 (100%) 0 Test 5 [Moving inversions, random pattern] 2/3 (66%) 1 Test 6 [Block move, 64-byte blocks] 3/3 (100%) 0 Test 7 [Moving inversions, 32-bit pattern] 3/3 (100%) 0 Test 8 [Random number sequence] 3/3 (100%) 0 Test 9 [Modulo 20, ones & zeros] 3/3 (100%) 0 Test 10 [Bit fade test, 2 patterns, 1 CPU] 3/3 (100%) 0 Test 13 [Hammer test] 2/2 (100%) 0 Last 10 Errors [Data Error] Test: 5, CPU: 0, Address: 49B51AC4C, Expected: 68608451, Actual: 68618451 Certification
