Very Need assistance with memory
  • Very Need assistance with memory
    I'm trying to rebulid my computer ( plan to buy additional memory of course gskill) and i need some advice.
    Motherboard: Asus P7H57D-V Evo
    Processor: Intel Core i3 530
    Memory: G Skill F3-12800CL7-2GB ECO ( total 4 GB )
    That this memory will be work correctly with my motherboard:
    G.Skill DDR3 8GB (2x4GB) RipjawsX 1600MHz CL7 (F3-12800CL7D-8GBXM)
    , if not which should model I must buy that will work correctly with my computer.
    Thanks a lot for your help
    Best Regards
    Canis1
    That should work for you, might only run @1333 not real familiar with that processor, but everything should be okay
      Hi Supahos,
      Thx for answer so I will buy this ripjaws , or is better buy some memory which is suggest from g.skill.
      Anyway when I tried turn on XMP on F3-12800CL7-2GB then mainbord didn't start.
      So I turn on d.o.c.p. and it work.
      Best Regards
      Canis1
        XMP is an intel setting so its not surprising it didn't work on an AMD rig, DOCP is their answer to XMP. If you already have a set running at 1600 then everything should be okay. Update your bios before you remove your old memory as it will make the upgrade more likely to work.
          And of course this I don't now.thank a lot for help so I will buy RipjawsX.
          Best Regards
          Canis1
