Memory Help Z87 Chipset
  • Memory Help Z87 Chipset
    I purchased the Asus Maximus Hero VI (Chipset Z87), I7-4770K(Haswell LGA1150) and G.SKILL Sniper Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-1866C9D-16GSR. http://www.ncix.com/products/?sku=78...ture=G%2ESkill
    I’m still waiting for the parts to arrive...
    I notice that the G.SKILL Sniper Series 16GB says:
    • Compatible with Intel LGA1155 and AMD APU/AM3+ platforms.
    • Optimized 1.5V low voltage.
    • Intel XMP support for 2nd and 3rd Generation Intel Core Processors.
    Will this RAM work with my setup?
    I’ve seen the new G.SKILL Trident X Series and its advertise for the 4th Generation Intel Core Processors & Z87 platform. Is there a difference between the two? Now I’m worried that I purchased the wrong Memory modules.
    You are fine.
    This sniper kit has been released prior to Intels 4th Gen, so thats why LGA1150 is not mentioned in the description.
