BSoD F3-12800CL9D-8GBRL Memory Management
  • BSoD F3-12800CL9D-8GBRL Memory Management
    Hello there. The last days i had blue screens from time to time. irql not less or equal were most of them and the latest one memory management. I run windows memory diagnostics and i got these results at event viewer attached on this post
    My specs are:
    CPU: Intel i5 2500
    Motherboard: Asus P8Z68 -V GEN3
    Memory: G.Skill Ripjaws 8GB DDR3 Non ECC CL9 1600MHz (F3-12800CL9D-8GBRL)
    Addition Information:
    Latest version of BIOS
    Optimized defaults settings at BIOS with XMP off
    Sounds like a module is defective. Test one at a time with XMP enabled and you should be able to determine the culprit. Send the memory in for RMA and a replacement should work better.
    http://www.gskill.com/rma.php
