MOBO--Asus P9X79-WS
Memory--F3-12800CL10Q2-64GBZL (matched set of 8x8GB)
(DDR3-1600 CL10-10-10-30 1.5 v)
(PC3-12800 8GX8 Intel XMP ready)
CPU--Intel Xeon E5-2690. 2.9 Ghz
Win 7 Pro
The system boots up showing 59GB. When I change the BIOS to XMP mode it will not boot(only one profile is present). I have tried the various methods noted on this site without success. Reset CMOS(removing battery), manual settings, etc. without success. I have updated to the latest BIOS as the first step(and in the middle of this--reflashed the BIOS in case it had become corrupted since the initial install). I have removed the memory sticks and reseated and have tried using less than the 8 sticks(the memory shows up proportionally less as each pair of sticks is takened out. I have also tried the various volt settings noted on this site for this MOBO). The speed noted when the system boots is 1333, and voltage is 1.5 volts.
Any help or advice would be greatly appreciated.
Win 7 Pro
