Random crashes and lockups
  • Random crashes and lockups
    Hi, recently started getting very random crashes, mainly when using browsers, it doesnt seem to crash when I am playing games, in browsers I still have sound but video locks up, then I get a black screen then the PC resets itself sometimes with a BSOD.
    I have formatted and re-installed win7, all updated drivers for everything inc fresh installs on browsers, still it crashes randomly.
    I have run Memtest and it chucks up 100's of errors, mainly "copying between **** and ****
    did not result in an accurate copy.
    My system has been running for about 2 years with 0 problems until now, nothing has been changed only the new SSD I installed 6 months ago, is my memory screwed ??
    System:
    Gigabyte X58A-UD3R rev 2
    I7 930
    6BG 3 sticks G skill perfect storm (it never ran stable @ stock2133 always ran it @1600)
    Nvidia 570GTX
    750W Corsair PSU
    thanks in advance
    Might be a stick or sticks going bad, try running memtest on each individually in slot 1
      doing that as we type, so far 58 errors from 30% on first stick
        one strange thing I have encountered, im supposed to fit one dimm in the white slot closest to the cpu for testing when running only one dimm, but, my pc posts but wont boot with the one dimm in that slot, but it does post/boot/work with it in the furthest white slot ??????
          ok, scrap that lol, that dimm must be the fubar'd one, just swapped to another dimm (first slot) and here I am
            Sounds like RMA time, will want to contact rma@gskill.com be sure and let them know you are in the U.K., believe they have a RMA facility in the Netherlands now which would be quicker and cheaper than going through China
              yup, think im gonna have to buy some cheapo stuff to tide me over, thanks for the help Tradesman.
                Sorry couldn't do more, let us know when you get the replacements
                  RMA filled in, RAM sent off, received by you
                  Is there any way to see/track the RMA process ? will I just get replacement sent or do I get any notification ?
                  thanks.
                  PS. dont thinm there was much more you could do Tradesman lol, thanks for the help
                    As long as your tracking says we received it, you should receive replacement very shortly.
                      OK, thank you.
                        Keep us updated
                          Whoop, RMA was sent out to me today, my old ram is no longer supported or do they have stuff as fast, so they are sending me 12GB back instead of 6GB, happy days, my old ram was 2133mhz, im getting 2000mhz back and 12GB, cant grumble at that can you, my 2133 ram never ran stable faster than 1600 anyway lol.
                          Im happy.
                            Sounds good, let us know how it goes when you get the new ones in
                              memory arrived this morning, installed it and now my PC is as stable as a 2 legged dog with an itchy bum.
                              Firstly it booted, started starting windows but shut down halfway through, then my PC couldnt find my SSD, 2 hours later my PC is running but keeps BSOD'ing.
                              I'm running the failsafe settings with XMP profile1, PC works fine until I start up a game, after 10-20 mins BSOD again.
                              It has been running 100% perfect with 4GB of cheapo ram that I bought while my ram was in RMA, now with the new ram installed its chaos.
                              Help.
                              System:
                              Gigabyte X58A-UD3R v2
                              i7 930
