I have an AMD FX8120, MSI 890fxa-gd65, and 2 sticks of gskill F3-10666CL9-4GBSR. The system is unstable at stock everything with the 8120. When I have my 965BE in, everything is fine. I have even reloaded my system with the 8120, BIOS reset of course, just to cover all the bases. No joy. Can someone please tell me ALL the settings for the BIOS to enable 1333 happiness?
F3-10666CL9-4GBSR and MSI 890FXA-GD65 and FX 8120
Originally posted by redbeardeddevil View PostI an AMD FX8120, MSI 890fxa-gd65, and 2 sticks of gskill F3-10666CL9-4GBSR. The system is unstable at stock everything with the 8120. When I have my 965BE in, everything is fine. I have even reloaded my system with the 8120, BIOS reset of course, just to cover all the bases. No joy. Can someone please tell me ALL the settings for the BIOS to enable 1333 happiness?
I am asking for all of the exact timings. Currently I have:
tcl 9
trcd 9
trp 9
tras 24
trc 33
trfc 110
twr 10
twtr 5
trrd 4
trtp 5
There are several others I need. I will try and post them later. I do not have regular internet where I live so getting on here is somewhat challenging.
With but 8GB of 1333, it should basically work by default, same as with your 965. Do you have the latest BIOS...might be that the mobo hasn't been updated for the FX CPUs....so make sure BIOS is current and any/all drivers are up to date.
Yes I do have the latest BIOS as of June or July this year. I have tested this extensively. I have tried other processors, all of which work except for the FX series CPUs. I work as a repair tech in a computer shop and have access to numerous tools, hardware and software wise. The only thing that I can think of beside the board being bad, is the memory controller hates this RAM.
Yep, the latest is 18.8 from Jul, have you tried the CPU on another mobo? or other DRAM with your mobo/CPU combo.......Have you checked CPU/socket for any thermal compound down there or bent/broken pins....The sticks are rather normal, basic sticks. Snipers (basically all freqs) generally run fine w/ anything, that's my preferred line of sticks to keep around for upgrades and just to have on hand.
