Hello Everyone
ustech@gskillusa.com
techsupport@gskill.com
See more
See less
Asus P5Q PRO & DDR2 PC2 8800 CL5 4GB/8GB kit
  • Asus P5Q PRO & DDR2 PC2 8800 CL5 4GB/8GB kit
    Hello
    I am currently planning a new build.
    I am planning on using:
    Asus P5Q PRO
    E8400 processor
    HD 4850
    and a PCIe sound card
    and I was planning on 4 gigs memory
    I am not sure yet weather to go with windows xp 32 bit or with vista 64 bit... havent made up my mind on this issue yet. I know that with the 32 bit I will not be able to see/use all of the 4gb - no biggie...
    Anyway, will the PC2 8800 4gb work well with this motherboard, is there a better option? I thought of using this ram, rather than the DDR2 800 because of the quickness of the memory.
    Any special massaging that would have to be done to any of the memory, either this or any suggested would be appreciated.
    Thanks!
    Paul
    this combination work fine and stable without any problem
    G.S
