F2-8000CL5D-4GPQ on a Gigabyte P45-UD3P Motherboard - Best settings
  • F2-8000CL5D-4GPQ on a Gigabyte P45-UD3P Motherboard - Best settings
    Just bought two sticks of G.Skill F2-8000CL5D-4GPQ,
    want to know the correct/best bios settings for maximum stability.
    Cheers,
    Matt
    With this set you'll want 5-5-5-15, 2.0 DRAM Voltage, and CR at 2T
      You should use the 3.00 memory multiplier if your CPU FSB is 333 (1333MHz).
        Thanks guys-
        no extra stuff for the Advanced Timing Control?
        ie.
        tRRD -
        tWTR -
        tWR -
        tRFC -
        tRTP -
        MCH Core -
        XMP - disabled, auto or profile 1?
          The other timings should be fine.
          MCH Core is fine on AUTO since you only have two modules.
          XMP should be disabled since you have manual settings input.
