I was wondering if anyone might know what the power specs are for the G.Skill F2-6400CL5D-2GBNQ (2x1GB DDR2-800) memory modules? I know that they are spec'ed for 1.8-2.0 volts, but I would like to know what typical, minimum, and maximum current draw or wattage would be for these modules.
The reason for the question is that I am upgrading my system, which had G.Skill 2x2GB + the F2-6400CL5D-2GBNQ (2x1GB) to total 8GB, and I had problems with the system spontaneously rebooting from Windows, and was able to eliminate the spontaneous reboots by switching from an Antec 500 power supply to an Ultra 750 power supply. However, even with the larger power supply, the system is marginal, in that if I attach all the hard drives that were in the system when I had the 6GB memory, I get the spontaneous reboots again.
The specifications for the Antec vs. Ultra power supply show a 3 amp difference (25 amps vs. 28 amps), so I'm curious what kind of current/power requirements were for the F2-6400CL5D-2GBNQ.
Thanks,
Jim
Thanks,
Jim
