GA-EP45-UD3R Motherboard with G.Skill F2-8500CL5D
  • GA-EP45-UD3R Motherboard with G.Skill F2-8500CL5D
    In 2009 I bought a Gigabyte GA-EP45-UD3R Rev 1.1 motherboard and G.Skill F2-8500CL5D-2GBPK to build a computer to run XP 32 bit. In 2011 I upgraded to windows 7 64 bit and purchased F2-8500CL5D-4GBPK to increase the RAM to 6 Gig in the computer. I updated the BIOS to F12 and tried all the setting I could find in the G.Skill forum and everywhere else to get both sets of RAM to run together at 1066 but nothing worked. Gave up and just ran F2-8500CL5D-4GBPK by itself at 1066 with no issues. The other day I ran across a thread of someone who had the same problem getting all 4 sticks to run at 1066 but was able to get 4 sticks to run at 800Mhz with 4-4-4-12 timings so the speed is almost equivalent. I was able to have the same success and am now running all 4 sticks at 800MHz with 4-4-4-12 timing.
    My question is about voltage because the memory is running at 800 MHz (not 1066) should I lower the DRAM voltage to 1.8 or 1.9 Volts? (currently DRAM is set at 2.02V)
    CPU Host Freq 333MHz (core 2 DUO Dual Core E8400)
    Performance Enhance – Standard
    Extreme memory profile Disabled
    System Multiplier 2.40B (2.4*333=800)
    DRAM timing Selectable – Manual
    CAS Latency – 4
    tRCD – 4
    tRP – 4
    tRAS - 12
    Command Rate – Auto
    MCH Core - 1.16 Volts
    tRRD – 3
    tWTR – 4
    tWR – 5
    tRFC – 52
    t RTP – 3
    Do you think I could lower the tRFC value anymore?
    If I run Memory Test 86+ for one pass with no issues does that mean I will not have any issues in Windows?
    I know both sets of RAM are good because they have run independently of each other for 2 years or more with no issues. Perhaps it is because they are not matched sets? Could I send these two RAM sets in to be exchanged for a matched set of 4 sticks? Would there be a charge?
    Voltage is fine because timings are CL4, so they will require more voltage.
    The tRFC is fine, that is good for 6GB.
    Boot up Windows to see if it is stable.
      so you are using DRAM of 2.02V?
      @Gskill tech, the ideal range on your ram says 1.8-1.9v. I take it that your approval means that is fine :-).
      Can you give us an ideal DRAM value per CL? (you can also post it in my own unsolved thread )
        Ddr2-800 4-4-4-12 2.0v
        ddr2-1066 5-5-5-15 2.10v
