Memory errors with abit aw9d max MB
  • Memory errors with abit aw9d max MB
    Hello
    I have 4 sticks of f2-6400cl4d-2gghk memory and I have recieved the following memory errors when running metest:
    error copying between 2bb974d abd 2bb9691 did not restult in an accurate copy. memtest has detected that your computer cannot accurately store data in RAM.
    pair 28499645 does not store values correctly.
    pair 26105847 does not store values correctly.
    error copying between 31cb8c and 31ca5d did not restult in an accurate copy. memtest has detected that your computer cannot accurately store data in RAM.
    Specs:
    memory: 4 sticks of f2-6400cl4d
    MoBo: ABit aw9d
    CPU: Intel Core 2 Duo E6600
    Running @ 5-5-5-15 (set to auto)
    I have tried different voltages and I am still getting memory errors.
    Anyone have any ideas?
    Tonyfo
    did you ad the mch voltage?
    G.S
      No I kept the mch voltage set to auto.
        it might be a little difficult to run 4 sticks on 975x chipset with CL4, especially the northbridge voltage can't be added
        G.S
          I changed the MCH to 2.0 and the ddr2v tp 2.2. I am still getting memory errors with Mem test. Any ideas or am I "stuck with 2 sticks of memory" that I can't use?
            Hi....
            Sorry to hear about your troubles. I use the same board. The MCH at 2.0 seems kind of high. Between this forum and Abit's (excellent moderators and users) you should be able to come up with a solution. It may take some tweaking. That is half the fun though (unless hardware is flat out incompatible).
            Good luck.
            DC
