Taipei, Taiwan (27 December 2017) - G.SKILL International Enterprise Co., Ltd., the world's leading manufacturer of extreme performance memory and gaming peripherals, is announcing the world's highest performance 16GB DDR4 SO-DIMM memory running at DDR4-3466MHz CL17-17-17-37 64GB (4x16GB) at 1.35V. Achievable only with rigorously hand-selected Samsung B-die DDR4 IC components, Ripjaws DDR4 SO-DIMM memory modules takes overclocking to new heights of system memory performance on small form factor (SSF) PCs.![]() The Perfect Trio: High Capacity, High Frequency, Low Timings The need of faster and larger memory kits continue to rise as modern day workloads slowly increases in both capacity and weight of the workload. G.SKILL prioritizes to deliver maximum memory performance across all memory capacities; by using 16GB modules, high end machines and workstation PCs can now fit into a SSF size motherboards. Shown in the following screenshot is the high capacity memory kit being tested for over 6 hours on an ASRock X299E-ITX/ac mini-ITX motherboard with the Intel Core i9-7900X processor. ![]() The Ultimate Performance Below is the screenshot of the same kit achieving 95231MB/s read, 94856MB/s write, and 90639MB/s copy using the AIDA64 memory benchmark. ![]() XMP 2.0 Support & Availability This new ultra-capacity high performance G.SKILL Ripjaws DDR4 SO-DIMM memory kit is equipped with the latest Intel XMP 2.0 technology for easy one-click memory overclocking, and will be available from authorized G.SKILL distribution partners in 2018 Q1. *** About G.SKILL Established in 1989 by PC hardware enthusiasts, G.SKILL specializes in high performance memory, SSD products, and gaming peripherals designed for PC gamers and enthusiasts around the world. Combining technical innovation and rock solid quality through our in-house testing lab and talented R&D team, G.SKILL continues to create record-breaking memory for each generation of hardware and hold the no. 1 brand title in overclocking memory. |
G.SKILL Releases World's Fastest 64GB DDR4 SO-DIMM Kit at 3466MHz CL17-17-17-37
