Memory 2133 Mhz BSOD B11OA Help Please
  • Memory 2133 Mhz BSOD B11OA Help Please
    Very new at over clocking only OC 3 Mother Boards looking for some recommendations Please. Long post sorry. At 4.4 Ghz BCLK 100 Multiplier 44 Per Core all settings default V-Core 1.245v Off Set + 0.05v No BSOD or issues.
    Issue with 4.5 V-Core 1.30v, or 4.6 GHz V Core 1.35v. LLC Auto or Ultra High at 140 Percent. On any other LLC settings.
    BSOD B110A
    Mother Board Asus Rampage 4 Black Edition
    CPU: I 7 4930K at 4.5Ghz V-Core 1.30v
    Heat Sink NH-D-14
    LLC Ultra High at 140 Percent Seems High
    V-Core 1.30v
    Off Set + 0.50v Seems High
    Memory G-Skill
    F3-17000CL9Q-16GBZH
    Series RipjawsZ
    Memory Type DDR3
    Capacity 16GB (4GBx4)
    Multi-Channel Kit Quad Channel Kit
    Tested Speed 2133MHz
    Tested Latency 9-11-10-28-2N
    Tested Voltage 1.65v
    Registered/Unbuffered Unbuffered
    Error Checking Non-ECC
    SPD Speed 1600MHz
    SPD Voltage 1.50v
    Fan lncluded No
    height 40 mm / 1.58 inch
    Warranty Lifetime
    Features Intel XMP (Extreme Memory Profile) Ready
    At 4.5 Ghz with 2133 Mhz Mem I get a BSOD with a B110A
    I think indicates a weak IMC on the CPU?
    Is this correct?
    VTT is used for Internal communications to the Chip Set.
    VCCSA voltage basically talks to the memory controller.
    Can I do this to the memory kit F3-17000CL9Q-16GBZH is 2133 MHz 16 Gb Kit
    to lower the stress on the IMC. Appears have 2 options run 8 GBs of 2133 or 16 Gb at 1600 Mhz? Unless I am missing other settings could be adjusted?
    F3-12800CL8Q-16GBZH
    Series RipjawsZ
    Memory Type DDR3
    Tested Speed 1600MHz
    Tested Latency 8-8-8-24-2N
    Tested Voltage 1.50v
    SPD Speed 1600MHz
    SPD Voltage 1.50v
    Fan lncluded No
    Warranty Lifetime
    With Core Voltage on Normal (Not Off Set) can use Load Line Calibration at 120 Percent Normal and no BSOD codes.
      LLC does not need to be Ultra for ~4.5GHz
      IMC should be OK, I think the issue is stable Voltage for CPU.
        Changed the LLC from Ultra High to Medium at 120 Percent. Recommended maximum for 4.45 GHz.
        Per the guide listed here Thank You
