How to enable XMP/ manually overclock G.SKILL memory with GIGABYTE Z77 & Ivy Bridge
This is a sticky topic.
  • How to enable XMP/ manually overclock G.SKILL memory with GIGABYTE Z77 & Ivy Bridge
    Someone may not be very familiar with BIOS, and we will show you how to enable XMP with Gigayte Z77 motherboard here
    Before enable XMP, please update with latest version of Motherboard BIOS and clear the CMOS.
    OR, you can manually adjust the BIOS as the memory Specification:
    Select the DRAM frequency & adjust the Selectable to expert:
    Adjust the Timing
    Adjust the DRAM voltage
    After you adjust/enable XMP profile, make sure that you save the changes & exit.
    Also, you can check the DRAM frequency/Timing by CPU-Z
