Asus Maximus V Gene + i7-3770K+32GB G.skill 2400
  • Asus Maximus V Gene + i7-3770K+32GB G.skill 2400
    Hi there!
    Sorry for my poor English. I`m from Russia.
    May be I wanna ask to late becouse now in 2017 year but I have a problem with my G.skill F3-2400C10Q-32GTX
    Here is my configuration
    Asus Maximus V gene
    Intel i7-3770K
    Seasonic Platinum 520 Fanless
    OCZ RVD3 X2 480GB
    OCZ RVD3 120GB
    Intel 520 120GB
    WD RED 1TB
    MSI GTX 1060 Gaming X
    In 2016 I steel worked with 3770 and memory perfect worked with 2400 ( 1.65). In 2017 I sold my 3770 and work on 3770K BUT the memory not working on 2400 when I overcloked CPU (nоw 4.6 MHz). I get down MHz on memory to 1333 to start system and they start ok.
    Can You help me!
    Which parametrs or otions I need to do to get my 2400 MHz on memory
    Does can my memory works on 2800 MHz?
    Which sreenshots need for You to help me?
    Hello! Does Anybody here is live?
      Do you have the latest BIOS?
      Enable XMP in BIOS and it should work fine.
      If not, test each stick to see if each can pass with XMP enabled.
        GSKILL TECH GSKILL TECH Thank You!!! I enabled XMP and set timing auto all works great at 2400!!!
