tips on overclocking Trident Z RGB - 3000mhz kit
  • tips on overclocking Trident Z RGB - 3000mhz kit
    i recently bought an rgb trident z 3000mhz 16gb kit ( 8gb x 2)
    xmp profile works fine for 3000mhz..
    but i want to oc the ram up to only 3200mhz...
    current hardware
    msi z170 krait gaming r6 siege
    i5-6600k @ 4.4ghz
    Intel i5 6600K @ 4.5GHz 1.36v 53c Max Temp
    Asrock Z270 Extreme4
    16GB Trident Z RGB 3000MHz
    Galax GTX 1070 Hall Of Fame
    Seasonic Prime Titanium 650W
    ID Cooling Frostflow 240L-W
    Which kit exactly, F4-3000C16D-16GTZR, F4-3000C15D-16GTZR or F4-3000C14D-16GTZR?
    I had the F4-3000C14D-16GTZR for a few days to play with on my ASUS ROG Maximus IX Apex. They did DDR4-3200 CL14 at their default voltage of 1.35V no problem. The board does overvolt the Vdimm a bit, so actual voltage was probably closer to 1.37V. However i did no benchmarks or stability runs, since i was primarily testing kits for DDR4-4133 with tight timings.
      hmmm. wait...
      its F4-3000C16D-16GTZR, its the one with the lose timings CL 16-18-18-38..
      i just enabled xmp to the timings and voltages will be set at 1.35v then i just change to clock to 3200.. it doesnt boot. lol so i guess im just not lucky?
      anyways it runs great at its rated overclock of 3000mhz.
        i tried 3100mhz its booted and i manage to do some benchmarks with it.. but going from 3000 to 3100mhz is i i think not really worth it.
