XMP timings for F4-3600C15D-16GTZ
  • XMP timings for F4-3600C15D-16GTZ
    I recently purchased the Trident F4-3600C16D-16GTZ 3600 16-16-16-36 1.35v kit. Working on OC settings tighter than my standard XMP ... I have set 15-15-15-35 which are the primaries for a kit that GSkill already sells [F4-3600C15D-16GTZ ]. Essentially I'm trying to turn my C16 kit into the C15 kit and need the secondary/tertiary timings as you would see in the ASRock Timing Configurator ...
    DL here ...
    Looks like this ...
    How do you load screenshots from your desktop???
    Anyway those who OC ram will no what I'm talking about right away ... Also let me know what mobo you were using with the F4-3600C15D-16GTZ kit
    From a performance perspective you would gain more from raising the memory ratio to 3733/3866/4000/4133. If your kit is comparable to mine, you can even keep the CL16 timings and just have to adjust Vdimm accordingly. I needed around 1.42V for 4000 16-16-16 on ASUS ROG Maximus VIII Gene with my kit.
    Upload your screenshot to an image hoster and then put the link to the picture they give you into [img] [/img] tags.
      Thanks for the reply ... your absolutely correct! I just wanted to compare my "base" timings to the C15 kit. Is there a way to even post a screenshot of timings in this forum?
      Been working on CR1 but no joy with my setup so far (6700K Z170 Asus M8Hero). I may not have a very strong kit ...
      Post HERE
      Here are the stock XMP timings for F4-3600C15D-16GTZ kit ...
      Follow the drama at the Link above for my CR1 "drama" ... happens to the best of us! Rookie mistake was holding me back
      Think I got the photo thing figured out? :O
      AHope this helps others ... AND thanks for the reply's! I'll upvote you if they allow
        I personally don't own a kit of F4-3600C15D-16GTZ, but i could ask around if you still want to give it's XMP timings a shot. However the read bandwidth in your screenshot looks alright for those settings. So if these are stable for you, i wouldn't even bother with it.
        For comparison purposes, my kit @ DDR4-3600 CL14-AUTO 1.39V:
